Are you saying you bought the pair of fog light bezels from Rockauto, shipped, for <$38? If yes, please post part number!just bought some from rock auto for 37.78 shipped for the pair
excuse the ignorance but what do you mean by 4" in height? Maybe I should ask what is the diameter of the fog light opening? Is it a circular opening or oblong (requiring you to use the ring since the piece is not flat)? Pics of the bezel with ruler would be appreciated. Thanks.I just got the bezels in today. The only issue is that it looks like there is a trim piece that goes on the outside of the hole. The hole measures 4.25 inches wide and 4 inches in height. I am researching a fog light now that will fit.
Fantastic! Thanks. Whoever does this first need to find a cheaper alternative for the ring insert, $20 each is ridiculous.http://www.rockauto.com/catalog/raframecatalog.php
you will have to search mazda then click on 2010 then select 5 , body exterior, bumper insert
part # VARIOUS MFR Part # MA1039104 More Information About this Part {#C29150C11A}
Fog Lamp Cover; w/Fog Lamps; RH Front insert
you will also have to buy lh side
Have a pic viewing it from the top and back? Btw, what kind of fogs are they?so i ended up going with some 4inch fog lights i found at orileys
check it out still need to wire the switch but ill probably go with a 4 pin relay and use the head light as a switch
nice work
