Hello all,
I just purchased a backup camera/mirror and have begun the wiring process. I was going off of a pdf I found on the forum for which wires to tap for reverse and switched 12v power at the kick panel. I think the reverse wire(yellow/red) is correct, but I'm wondering on the 12v switched power. Once connected the mirror does not power up at all. The pdf indicates a Black/Yellow wire in a 6 pin connector for 12v switched power. This does not seem to be correct for a 2011 Touring CX-9. Does anyone know if there is an actual wire I can tap at the kick panel for 12v and what it's colors would be?
Thank you!
Thank you!
