That was also my take from the slides I saw.
Apparently, it takes a lot to make this work: very high pressure direct injectors that can inject fuel later in the compression stroke and still produce a homogeneous charge, VVT, a supercharger to keep the mixture lean at higher rpm, an intercooler and an EGR cooler, and my favorite part is that they sample the cylinder pressure throughout each combustion cycle and compare it to a target curve. That's normally something you might do in the lab, but to use it in the control loop of a real vehicle is very cool.
This sounds like an expensive engine.
