I don't think this one was posted before and they are using a CX-3 instead of a CX-5 but interesting results on i-ACTIV
It seems Mazdas predictive i-Activ all-wheel drive technology is indeed pretty good comparing to Subaru and Jeep. My only complaint is the fuel efficiency especially on the highway. With newly updated 2016 EPA fuel economy rating, the penalty for having an AWD on CX-5 is looming to 4 mpg on the highway, from 33 to 29, whereas others only suffer 1 mpg!
Our old and faithful 1998 Honda CR-V AWD has similar AWD system setup mechanical wise with clutch pack in the rear differential like CX-5. But based on new EPA fuel economy ratings, 1998 CR-V FWD has 21/19/23 and 1998 CR-V AWD has 20/19/23 combined/city/hwy. See there's almost no penalty on fuel economy by having an AWD over a FWD! Not to mention in real world situation even with 175,523 miles on our CR-V, I still can easily and constantly get 22 mpg in city and 25.5 mpg on highway with my driving style which are way better than EPA ratings! On the other hand it's almost impossible for me to meet EPA highway rating at 30 mpg with my AWD CX-5 on the highway! This's something me and Unobtanium are complaining about since day one - EPA fuel economy estimates for CX-5 AWD are too optimistic...
"Put a stout V6 or I6 in the CX-5, and the mileage disparity would disappear, and it would be getting similar mileage as the Jeeps do, where speed doesn't matter, 70, or 85, same thing. "
Not the target market for Mazda. And they have to use one platform WW for their size. And they seem to know how to fit into the gaps left by the other players. If not, there wouldn't be here.
Yes, but what gearing differences are there with the FWD and the AWD CR-V?
I am showing they are identical at 4.36. However, Mazda did NOT do this with the CX-5 AWD.
Also, yes, I still feel that Mazda "gamed" the EPA test via programming etc. and once you push the rpm/load outside of the EPA test protocol, you see drastically diminished results.
The gearing differences explain FWD/AWD model disparities though, not the AWD system's function or weight.
Yes, our Honda CR-V has the same final gear ratio between FWD and AWD. And yes I do agree the gearing difference does play the major role of making our CX-5 AWD less fuel efficient. This is also the reason why while I have no trouble meeting EPA city rating but have very hard time to meet EPA highway rating at constant highway speed!Yes, but what gearing differences are there with the FWD and the AWD CR-V?
This is not a puny motor, except when compared to domestic US vehicles, The 2.0 is pretty weak compared to other 2.0's, and the 2.5L isn't much to brag about either. All of the advances are in efficiency as far as I'm concerned. Hell, a 15 year old Sentra is just as powerful with its 2.0. Let's not even bring in actual performance application 2.0's from the JDM. Regardless, I was comparing it to V8 and V6 options which do great on the highway because they aren't having to buzz away manically. For example, at 60mph, my Z06 was pushing like 1400rpm. I know, it's a corvette, but my Grand Jeep Cherokee was only doing about 2K at 80mph... where fuel economy was until recently "un-American". The 2L AWD was in the US/is still sold in other markets.
I find it hard to believe they put final drive differences only for the small added weight. Perhaps it is there to get a more torquey 1st gear, for added usability in off-road situations? In any case, it can definitely play a role in how efficient the AWD is. Yeah, I listed all of those. The added weight is less than the variance in the gas tank.
I think you'll find that high efficiency vehicle (i.e. your gas guzzler, or even an old CR-V, with significantly less weight and smaller engine, is no longer considered efficient and does not count) could easily go below their max efficiency when off optimal conditions. If they could have easily maintained it, they could have scored better in optimal conditions.
It is not because they "gamed" anything, it is because it is hard to get that efficient. I've seen it with my wife's former Prius, that with a lot of effort could get > 52 MPG, but with a heavy foot and apathy could fall below 45 MPG.
Also, with a V6 there will certainly be more power, unnecessarily so for most owners, but would also degrade the efficiency, increase price and thus make this vehicle less attractive.
I also agree that Mazda "gamed" the EPA test via programming etc. and once you push the rpm/load outside of the EPA test protocol, you see drastically diminished results[/B]. But I believe every car manufacture more or less is doing it under the pressure of competition and future tougher CAFE standard.
After the longest time of turning my TCS off completely, I now use it pretty much all the time. A little of a month ago I went on a cruise with my Mazda club. I decided to leave the TCS on this time, and I noticed that I was out gripping some of the mazdaspeeds when were doing the twisties. I'm talking cliffside, 90/180/270 degree turns. I expected the advantage in power on cornering over the wrong wheel drive Mazdaspeeds/3's but I realized from watching their vehicle movements (and listening) that I was outgripping them in similar gears. SO now I always leave TCS on, and I figured out that the TCS will allow a powerslide as long as the throttle is constant or RPM is increasing. In fact I went about 110* turn from a stop, redline and the car did not zigzag from DSC engaging like it does with the TCS off. I'm curious how the Honduh awd performs under low gear/high RPM cornering myself.
Yeah I agree with you on this as I had exact experience driving our AWD CX-5 on I-45 under 70 mph all the way at 75-mph zone just to verify if I could hit that phantom 30-MPG EPA highway rating! True that was a pretty dangerous experiment as everybody else was driving at least 80! And I also have to say the same thing that our worst fuel economy performance on the highway for every vehicle we've owned, except the CX-5, is EPA highway rating!My Jeep's worst performance (not counting 20mph headwinds and blinding rain) was EPA. It's best performance (cruising at 55-60) was 23mpg (about 4-5mpg over rated). My CX-5 is the opposite. The only time it hits EPA, is when I hypermile it and piss the world around me off by clogging the lane.
I honestly don't know how much I believe engines have variances THAT large. The CX-5 engine is modern, and is made to pretty exacting tolerances. I remember back when I bought my Z06, I asked about the engine dyno, etc. and it was pretty much established that all LS7's were +- about 10hp SAE or so. There were no "freaks", and there were no "dogs". That is a 500+hp engine, too. I am betting the CX-5's 2.5L mill is +- 2% at the very most.Yeah I agree with you on this as I had exact experience driving our AWD CX-5 on I-45 under 70 mph all the way at 75-mph zone just to verify if I could hit that phantom 30-MPG EPA highway rating! True that was a pretty dangerous experiment as everybody else was driving at least 80! And I also have to say the same thing that our worst fuel economy performance on the highway for every vehicle we've owned, except the CX-5, is EPA highway rating!
Actually I was skeptical when the first time I read your fuel economy complaint on highway with your AWD CX-5 when you had a road trip in Texas. Once I made our first road trip with our AWD CX-5 to Houston, I fully agree with your accessment.
Since there're people getting and surpassing 30 mpg with ease on their AWD CX-5, I also suspect each SkyActiv-G 2.5L engine would have drastically different performance on fuel efficiency and my particular engine just happen to be a one much less efficient assembled from factory!
Again, to others, I am quite pleased with my CX-5, I am just frustrated at the gap between expectation and reality. Much like you would be happy to have won $800K on a lottery, but I damn well bet you'd be irked if you were promised $1M USD after taxes, and the $800K was what you got. Can ANYONE on this forum say they wouldn't be asking some questions about that? And here I am, spent a helluva lot more than a lotto ticket, and I'm getting less than promised. Think about that one for a while.
