1 12fretter Member : Mazda 3 Sedan Touring Nov 5, 2012 #1 Two questions: Does the pre-Skyactiv engine have a timing belt or chain? Does this engine require fully synthetic oil? Thanks. 12fretter
C cburrell Member : 2013 CX-5 Touring, 2016 Mazda 6 Sport Nov 10, 2012 #2 Pretty sure it has chains and yes it uses fully synthetic oil that needs to be changed every 7500 miles.
H HandA Member : Mazda3 and CX-5 Dec 13, 2012 #3 Mazda has their own oil (although they recommend Castrol on their site) that is supposed to be a higher moly content: Trevor HandA Accessories http://Mazda.HandA.com/mazda3.html
N njaremka Wiggity-Wack-O-Tack Contributor : 2012 Mini R55 Dec 13, 2012 #4 12fretter said: Two questions: Does the pre-Skyactiv engine have a timing belt or chain? Does this engine require fully synthetic oil? Thanks. 12fretter Click to expand... chain. match the grade (5w-30, or whatever the manual says) and you'll be fine. if you change your own oil, use synthetic for extra protection.
