SeR_Cyclops
- Mazdaspeed Protege
As long as they were coated I dont think It would matter much.
I would say leave it internal waste gate actuator because they make t25 turbine housings with 38mm v band outlets. I've seen them at atpturbo.com
I'm ok with that. I want external wg with stock t2 location mainly cause I have popes dp, and external wg is so much more reliable
+1 on the 409 for sure FUNCTION OF FORM any day!!!
EDIT: has anybody wrapped a tubular with the the header heat wrap stuff?? ive seen cars with it but it always looks like it doesnt last long...
they dont work on our car's. The oulet for the vband would put the ewg through the block lol. They are more for a turbo layout like on the dsm's. Where the intake of the turbo is facing the passenger side.
I guess it comes down to personal experience. I been through 6 wga in under 3 years all failing or not holding boost. I am for one looking to get the **** away from the stock craptastic setup.I've been running internally gated for 6 years now on different car's and never once have i had a wastegate fail. i'm not arguing that external's are better for boost control i'm just saying as far as reliability at least for me its negligible.
its been off the brake booster line.....You need to get your Vac source off the IM and put in on the brake booster. I replaced 2 WGAs when it was done that way and then After I moved it I have had never had problems and it has been 2-3years. I think the IM causes premature failure.
I also want a screamer pipe lol
