Ok I think my theory about the current being split to ground is garbage. The resistor in this configuration does basically nothing. I measured the voltage the AEM sees with and without the resistor and it's identical, about 1.6V with just the ignition on, and about 2.2 at idle. There is practically no current running through these wires, so no amount of resistors is going to change the voltage, unless you set up a divider. Which means put another resistor in series with the first one to ground and tap between the two resistors. Look up voltage divider. I believe this is what they meant to put on the Miata diagram, and whoever drew it messed up and forgot the second resistor.
I also tried the bypass jumper that came with the AEM. The car started and immediately stalled. I then cut the resistor since I wanted to be sure I wasn't altering the MAF signal, and it still stalled. Then I plugged the AEM back in and it still stalled. I then measured the MAF output voltage and it was sky high 8.24V. Now I second guessed myself that maybe the resistor was lowering the voltage and I just measured the current incorrectly.
So I hooked the car back up stock and it started just fine, no CEL. Then I went to go measure the MAF output and my multimeter died on me. Fuse blew, and I couldn't find a replacement. I soldered some wire across the fuse terminals and it was still dead. It's fried. So I am done for today.
I have given some thought to this MAF situation. We really shouldn't be intercepting the MAF signal. The AEM can output 5.87V max, which is nowhere near the 12V max of our MAF. Even if you setup a voltage divider or use a potentiometer and get the signal within the AEM's range, you'll have to compensate with twice the fuel and you'll never be able to have a true base calibration.
I am curious what my CEL is. I am going to buy a scanner tomorrow when I buy a new multimeter. I am guessing it's a lean code since it took a couple minutes for the CEL to pop up. Could also be an O2 code, since I did not follow the AEM instructions and put an isolation resistor on the O2 wire. I think this is why I got a few 0's in my data log.
Hopefully, I'll get some more time this week to play with it.
