whenever when i backing up and brake, there is one or two knocking noise from the back of the car, is it the brake or what?
i already replaced the rear sway bar bushing........
as you press the brake, half way down, all the way? At what point do you hear it? Have you checked your lug nuts? Is it one side or both(you may need to have someone back there to tell)?
do you have a manual or auto? when i back up, and let the clutch in, i hear a whining sound from the tranny that is around 90-120 cpm. it only happens in reverse and when i am slowing down in first.
