rolandventura
My trusty 323F (1992) has developed a really weird electrical problem. One day I was driving along and the light failure warning light came on in the dash. I then noticed that my rear break lights were permanently on (irrelevant of the pedal position). I disconnected the break pedal switch hoping that it was stuck in the "on" position but nothing changed. I checked the bulbs and everything was OK with the brake and rear light filaments.
The rear brake lights stay on even when the key is removed from the ignition and the only way I can get the lights to go off is to remove the fuse controlling the electrics for the inside of the car. When I remove the fuse covering the internal electronics the brake lights work as normal but the central locking and radio now (obviously) do not work. However, I then noticed that when I put my foot on the brake pedal both the radio and the central locking miraculously started working again and stopped working when I took my foot off the break pedal (even thought the fuse was still removed). I removed the radio hoping it was causing the problem but nothing changed.
I would be very grateful to hear any suggestions, exorcism techniques, links to other forums/pages etc.
Many thanks
Roland.
Many thanks
Roland.
