Bigg Tim said:Yeah, you probably don't need the xtra injectors at that level. Beau said you were going to run at least 12, so you would need them for that. The throttle switch point is okay to use, but I tried all the settings and found the amp to be the best. There were times that I did not want to go full rich at WOT because there was not enough boost to worry about it. Go ahead and trim as much fuel as you need to get er running right man!!!
I know that 1-2 pounds before the TM comes on isn't bad, but sometimes it seems to build more than that when i just had the amp switch. The turbo spools sooo quickly that when the boost builds like that and i still see A/f in the 13's i freak out. I know what you mean about having it come on when i don't want it though. I was going up a hill to my house in 5th and i didn't even realize i was at full throttle and it came on and bogged down because i wasn't under very much boost.
