Hello, I recently just bought a 2016 mazda cx-5 that was recently in a small little wreck and now im stuck. So the only problem im having is alot of system malfunction lights. Malfunctions are Parking brake Malfunction, TPMS Malfunction, Traction Control Malfunction, Keyless entry Malfunction. I ran the computer reader to it and the codes I got are
1: TCS(traction Control system) Disable switch
2: ABS(anti Braking system) Pump Motor Control
3: Invalid data recieved from ECM(Electric control module)/PCM(Powertrain control module)
Took it to a dealer and they said they found DTC U0415 for invalid data received from the anti lock braking system control module A. They inspected and found the ABS module has a malfunction to the EPB system. They recommend replacing ABS module.
Any Ideas what can be causing this? Was at first thinking body control module maybe bad but guess not.
The Parking Brake does still work. It engages and dis-engages fine. The buttons to turn on traction control doesnt seem to work because the lights are on the dash.
