Timberwolves
- 2010 CX-7
New to the forum wanted to say hello to everyone. Having a transmission problem. Seemed like transmission was slipping & shifting gears rough. Checked fluid good & not burnt. Start car & no reverse. AT light comes on and bring to mechanic. He looks it over and can't find anything recommends bringing to transmission shop. Bring it to shop this am same symptoms. Transmission mechanic starts car & check engine light is now on. Test drives & reads transmission codes & engine codes. On the transmission scanner he says he is getting a P006C code. Map-Turbo sensor code. Doesn't get code on engine side. On test drive manually shifting everything is fine including reverse. When he puts in drive displays same symptoms. The car has 60,900 miles on it & purchased new by me. The warranty expired 7 months & 900 miles ago. Could that error code from the sensor have anything to do with the transmission issue or just a coincidence ? At a loss, hoping it doesn't need a new transmission. Thanks for the help. John
