It's not, because it still does it after it get up to running tempYou sure it's not motor mounts? I get a little chatter on the first couple starts when it's cold, but after that it feels good and grabs hard and consistently. Motor mounts took out all the slop from the engine absorbing torque instead of transferring it.
Sent from my LG V20 using Tapatalk
fidanza flywheel and south bend clutch.
It lurch, sometimes it doesn't want to grabIf a motor mount is worn bad enough that it lets metal touch metal it will rattle and vibrate like crazy. They're worth looking at.
If you slip the clutch when taking off, does the car lurch or roll smoothly? If the clutch doesn't slip smoothly, that's the problem
Sent from my SM-G925T using Tapatalk
This one?Then I would go with a standard flywheel and Exedy clutch kit.
This one?
http://shop.exedyusa.com/exedy-raci...stage-1-organic-clutch-kit/10807/i-34417.aspx
