Hi all. I just finished my engine rebuild/turbo build and when i hooked everything back up, the manual transmission is locked up or something. When i try to shift into 1st gear and ease off the clutch, the car stalls and dies if i fully release the clutch. The wheels are not spinning even when jacked up on 2 stands. The paasenger axle spins freely. The driver side axle has some resistance. I bled the clutch line and i bled the driver brake caliper. The shift linkage is hooked up. The transmission has a crack thats about 6 inches long. It starts near the area where the shift linkage touches the transmission (behind the differential) and ends near the speed sensor under the transmission (near the main bearing support plate). The stick also wont shift into 3rd or 5th gear. I have to fight to get into 2nd or reverse. 1st and 4th are smooth. I tried quicksteel to patch the crack. It slowed it down but its still leaking. I added fluid to see if it would help me shift. It didnt. Can anyone help me figure out whats wrong? The only thing i changed in the trans was the throwout bearing. Also i snapped the wire that connects to the reverse light switch (drivers side front bottom of the trans).
