Both axles have a c-clip.
The carrier bearing holds the joint shaft in without a c-clip...
EDIT...
Apparently the joint shaft DOES have a c-clip...
Although it may not be necessary because it is held in place by the hanger bearing as mentioned ?? (I dunno... I removed both axles to do my bearings but didn't need to remove my joint shaft)
