I'd like to hard wire my radar detector into the 2016 GT I just picked up last week. I did read through the earlier thread on hard wiring a detector into an older CX-5, which included a link to a 2012 service manual which had A pillar trim removal instructions. Those instructions called for the cutting of a wire to remove the trim, but I did not see how to reconnect that wire when the trim is installed. Those instructions also called for installing new clips, but if that is required, I'm not sure what clip I need or where to get it.
If I can get the A pillar trim off without breaking anything, it looks like the rest of the job is pretty easy. It looks like there are a couple of empty switched fuse blocks that would be easy to tap into and the fuse box is in a perfect location for a project like this.
Thanks for any advice.
