s***, bro! Did someone check the rev limiter on a regular basis in that b****? The oil pan looks like s*** at that mileage.Last week I bought a non-running P5. Rod through the block @ 77K miles.
Picked up the car today with a new used motor with a bit under 50K miles.
http://mn-hsta.org/Original 77K Motor.jpg
Dropped the broken motor at the salvage yard to get my core deposit back.
Hmmm, needs sway bar bushings. Pulled the extraneous wiring from the previous owner's stereo installation out. Pulled the rear door panels. Love the wires wrapped around the cone wires in the rear door speakers to extend back to the rear hatch area. Hmmm, there is low gauge power lead off the battery live and laying in the hatch area. Glad it hasn't touched the ground wire which is also laying back there. Stock speakers. Gonna have to go.
Hmmm the spare tire well is damp, as well as the jack storage area. I wonder if there is a leak? Space saver spare is showing cord....
The power mirrors won't tilt down or in. Pull the drivers door panel and the mirror switch. Pull the switch apart and clean it. Doesn't look too bad. Bend the contacts a bit, to ensure that they're making good contact, put a dab of dielectric grease and reassemble the switch and test it, Mirrors still won't tilt down or in?!?! Oh well, stock speakers in the front doors, so the door is going to have to come apart again anyway.
Program the stereo. Ahh, there is a CD in it. Popular teen music. Matches the Eminem CD I got out of the glove compartment.
That's it for today.
Yep, yep and yep! I had actually been driving around most of the morning but I took the P5 around the block just to make sure it was up to temperature. As per the FSM, pulled the fuel relay, opened the gas cap, started the car and ran it until it died, cranked it a few extra times for good measure, pulled the plugs and then tested each cylinder twice in a row (crank each cylinder about 5 times with the throttle fully depressed). This is the second time a compression test has yielded ~200 psi across all four. Time to do a leakdown next, just need to source a tester and an air tank.if you had bad rings, your compression would be way down. How did you do the test? Warm engine, no spark plugs installed, throttle wide open?
LOL, to the head. I was reinstalling it when it fell off the studs and hit me just above my right eye (I posted a before-stitch cellphone pic in the 'Member Pics II' thread). Note to self, always hold that thing up with one hand.geeDang... swaybar to the ???? 5 stitches... hope your ok
Thanks! Man, who knew working on cars was dangerous?! This definitely goes down as one of my more funny injuries. Considering the other things I was doing today (compression test, fuel rail install) I'm glad I was hurt by the swaybar and not by something like the engine bay catching on fire!Oh man, other than 5 stitches and a stick, glad to hear you are ok.
Decided to talk to bazooka joe about turboing the P5. 6 psi at 50k miles with no problems? sounds really intriguing to me so maybe I will start gathering parts to turbo her next summer. That would be soooo much fun.
