wastegate adjustment?
5 pound spring currently the car has stock turbo, at 11psi right now want to drop it to 5, i just want to adjust the rod lenght
MBC is can be used to raise the boost, once you set the WGA lower. Since you already have the 5 psi spring in you just need to adjust the length of the rod.
curse alot and hope u can get a wrench in there.. lol. honestly its a b****.. u have to contort your hand to angles it shouldnt be bent.. or just take the wga all the way off and adjust it and reinstall it
Latest posts
