There is nothing to disagree with. That is the way the tire ratios are calculated. Always have been. The rim has nothing to do with the tires size except to limit the possible width. For example, a 205-50-18 has a much shorter sidewall than a 275-50-18. Or, in our case, the sidewall is almost the exact same height (as is the circumference) on a 255-55-18 as it is on a 235-60-18. Simple math.
http://www.dsm.org/tools/tiresize.htm
Type in a 255-55-18 and it will list every single tire that is the same height. If you look at the 18 inch results, 60 series, you will see a 234 mm result (235).
