- 2002 BJFW, 2007 BK3P, 1979 SA22C, 2005 BK3P
did you reuse the stock mounting bracket? remove it and retighten the manifold if so.
check the gasket material on the throttle body. if this was not THOROUGHLY cleaned there are going to be issues there.
I'm reading around 15 vacuum but it used to read around 16-18. if I am cruising in gear its around 15 if its in neutral around 12. but it doesn't go down to 20 like it used to when I shift. When I first start the car its at 10.
subbin probably puttin it on this weekend
we're local if you need us (drive)
you should be pulln at least 20-22 vacuum at idle...
how much would it be for pg to put it on? or is it easy enough that i should do it my self/
