- 2003 Protege5
OK remember I would consider myself a mechanical novice...
I have removed my intake manifold... drained the coolant, cut that stupid plastic holder for the wire harness, cut the bolt that goes into the firewall but I still can't get a good straight fit for the 17mm nuts for the mount. I realized I needed about 1cm more clearance to get a good fit for the mount bolts, so (as you see in the pic) I'm RE-sawing that bolt off (buy hand -___-)
But, the problem I see now after I get rid of this firewall bolt to get a good fit; If I attach long-enough extension on a breaker bar to get enough room to use all my strength to get that mount bolt off, this stupid thing gets in the way (I'm assuming brake hydraulic lines).
I'm a bit frustrated - seeing as it took me around 2.5 hours just to get the manifold off -and wishing I would have just spent money to get a mechanic to do this. Nevertheless, I started it and intend to finish it. What should I do? I've searched the forums and basically found one thread on it. It didn't really help much for me at least - In fact I think the thread ended up with the OP taking it to a mechanic. Any help would be much appreciated.
-----MINNIE SUB THREAD--------
P.S. - Part of this project was to finally swap in the ZE manifold, but I can't get the factory fuel lines to fit onto the fuel rail, where the pulsation damper was in the FS DE fuel rail. It seems that ZE fuel rail end is too fat for the factory fuel lines. Can anyone that has swapped the ZE manifold help me out as well?
