I have been impressed with quality of the VLEDS (Bellingham, WA)
Still running strong in my fogs, DRL, cargo and trailer lights....
I used P13W in mine but I have HIDs.
I can see how the p13w would work for just a DRL(in a Tech model like yours), BUT, I see the VLED website says " Not for use as a headlight or primary source of light for night time driving", SO, these would not work for me as a replacement for my DRL/highbeam (in my non-Tech) I am assuming.
Sorry for the upcoming dumb question perhaps but I am bot an expert:
Is there any lighting upgrades that can be done on a 2016 GT other than the interior lighting ?
Sent from my iPhone using Tapatalk
You are going to lose your high beam... I think it is the 9005 for the non-tech
I believe you need something like this too so LEDs aren't dim from DRL.
https://www.ebay.com (commissions earned)
License plate lights, reverse lights. Those are the two easy ones I know of. You can easily convert those to LED and give your car an even much better look. Cheap too.
I ordered those December 13th and still havent received them.
I opened an issue with seller for refund which he did
Hope they do eventually come in
I've already converted the license plate lights.
Do you know what bulb are required for reverse ?
If you're talking about rear license plate lights, I use LEDs from this https://www.ebay.com (commissions earned) with newer and brighter 5730 chips. They're there for 3 months now and have no issues.
Thanks for the input. I agree that it is a good buy once our dollar goes good. Where I live the temp is pretty cold as well. Much worst than Quebec Can you show me where I can see the thread for the guy who live in quebec?A post on another thread from a guy in Quebec (where as you know winter temperatures get pretty darn cold) has installed the VLED brand LED's for his foglights which he says have worked really well. I believe he has a non-Tech version so check out the following link.
http://www.vleds.com/bulb-type/fog-lights/h11/white-10-led-drl-fog-light-bulbs-h11-h16-1-pair.html
VLED's 5000K foglight LED bulbs would be the way to go as they produce a whiter light vs the 6000K which would give off a slightly bluish hue (so I have read).
These will be my bulb of choice to buy once the $C exchange rate improves as I live in Canada as well.
I used these:
http://www.usa.philips.com/c-p/12841B2/vision-led-exterior-lighting
Rear firing LED works with the CX-5 silver reflector style reverse lights.
$19 at Pep Boys or from Amazon. More elsewhere online, despite claiming "discount".
FML!
Cheapest I found are 20$ + 10$ for shipping
That is 30$, US!! For 2 bulbs...again, FML!
I also wonder what are the error codes being mentioned here?
Sent from my SGH-I337M using Tapatalk
I just bit the bullet and found some at 33$ CDN on Amazon. I believe its a good product and will last the lifetime of the car ( at least thats how i convinced myself of spending *%*@$!? 38$ tx incl. for 2 tiny light bulbs!!
CX-5 doesn't check the burned-out bulbs. You won't have load issues and get any error codes by swapping these OEM incandescent bulbs (not halogen) for dome, map, license plate, reverse with LEDs. Newer 5730 LED chip is definitely brighter. Who knows the longevity of these eBay LEDs. They're so cheap anyway and I haven't had any issues for 4 months now.I take it that the 5730 chips are more robust and can handle heat better --->less issues with regards to loading/codes?If you're talking about rear license plate lights, I use LEDs from this https://www.ebay.com (commissions earned) with newer and brighter 5730 chips. They're there for 3 months now and have no issues.
