Rotary-Amuse
- 1993 Mazda RX-7, 2004 Audi TT 225 quattro Coupe
here's my project car. nothing too crazy.
1993 Mazda RX-7 Touring
13b 1.3L Twin Turbo Rotary Engine; 348.18rwhp & 315.94rwtq at 13psi; 330.99rwhp & 277.06rwtq at 11psi; 2690 pounds without driver and gas
Engine
HKS S-Type Front Mount Intercooler, Downpipe, Racing Suction Kit, Carbon Ti Exhaust, SSQV Blow Off Valve, Circle Earth Grounding Kit, US Spec 1 Turbo Timer, EVC V Boost Controller; Pettit Resonated Mid Pipe, Air Pump Eliminator Pulley Kit, Air Separator Tank; Efini Y-pipe; Unorthodox Racing SS Pulley Kit; Ground Zero/Pineapple Racing Oil Pan; Noltec Motor Mounts; A'PEXi Power FC, FC Commander; Fluidyne Radiator; Carbing Cooling Panel; Walbro 255lph Fuel Pump; RC Injectors 550cc Primary Injectors, 1200cc Secondary Injectors; NGK BUR7EQ Spark Plugs, BUR9EQ Spark Plugs; Castrol 20w50 Motor Oil
Suspension
TEIN Super Street Coilovers, Solid Upper Pillow Ball Mounts; Racing Beat 1.25" Front Sway Bar, Front Sway Bar Brace, Rear Sway Bar; Cusco D-Style Front Strut Tower Bar; Rotary Extreme Rear Strut Tower Bar; RX-7.com Trailing Arms, Toe Links
Transmission
ACT 6 Puck Racing Clutch, Pro-Lite Flywheel; Mazda Factory Clutch Disc; Cusco 1.5way LSD; RX-7.com Solid Differential Bushings B&M Short Throw Shifter; Stainless Steel Clutch Line; Red Line 75w140 Gear Oil, Limited Slip Friction Modifier
Brakes and Tires
KVR Slotted Rotors, Carbon Brakes; RBF600 Brake Fluid; Goodridge Stainless Steel Brake Line; Kumho Escta Supra 712 Tires
Interior
Sparco Evo Seat, Sprint V Seat, Globe X Shift Knob, 5 Point Cam Lock Harnesses, Leather Shift Boot, Leather E-brake Boot, 345 Wheel; NRG Quick Release Kit, Hub Adapter; MemoryFab Super-lo Seat Rail; Autopower Race Roll Bar; Carbon Fiber Globe Box; Rotary Extreme Carbon Fiber Door Sills; Benevento 16 Piece Carbon Fiber Overlay; Bose Speakers Removed, Acoustic Wave System Removed, Stereo; AEM Wideband AFR Gauge; Autometer Carbon Fiber Series Water Temp Gauge, Oil Temp Gauge, Oil Pressure Gauge, Boost Gauge, Exhaust Gas Temp Gauge, Triple Gauge Pod; Tri-Power Center Channel Dual Gauge Pod; RX-7.com FC Commander Holder; Viper 791XV Alarm; Lo/Jack Car Security System
Exterior
Powdercoated Rims; Rotary Extreme Carbon Fiber N1 Hood, Carbon Fiber Side Skirts
Engine
Suspension
Transmission
Brakes and Tires
Interior
Exterior
