So I had an issue with a rear driver side caliper leaking and the Racing beat sway bar bracket snapping also on the drivers side.
There was a heavy vibration in the car, when I changed the caliper/rotor it was much better. Yesterday I took the sway bar out as a whole the vibration is 20% of what it initally was.
Couple weeks back when it was really bad my friends were driving beside me and told me the rear drivers side wheel was hopping at around 100km/h (canadian eh!)
It still vibrates a bit wanted to ask if n e one has had similar problems. The bolts are all torqued on properly and the air is at 32psi as per the sidewall of the tire.
