About an inch and half maybe two. It looks good too. If you search them on google or on here there are plenty of pictures haha also with the tires it all depends on wether you have camber or not. Right now I'm running 17x7s with 3 degrees of camber in the rear and I'm barely not hitting the strut, but I have extended lug studs and 10mm spacers and I'm tired stretching. It all depends on your set up for the wheel width. I've seen people with 285 and people with 195. If you gave more info we would be able to help more
