Post Pictures of Your CX-5 Mods, Upgrades and Accessories!
Send him a message first. The item has been up for a while. https://www.ebay.com (commissions earned)
thanks Chris, I also found another seller on eBay now.... from Japan with smoke, clear and red lens options, https://www.ebay.com (commissions earned)
is the install pretty straightforward, is full rear bumper removal required ? can I just remove the factory lights by removing the rear bottom undercarriage panels ?
also do I splice right into the rear lights , is there any obstructions or drilling required to get to the quarter panel wiring ? sorry for all the questions, just want to know what I'm getting myself into, thanks in advance.
I took the wheel off for easier access but with stock suspension you should have enough space just by using a jack. You can splice into whatever wires you want. Each assembly has two led arrays. You can have blinker/brake/running in any combination or on the same line. I just spliced mine with generic wire taps.
So, finally got them Topline fender flares painted and fitted. Had to mount 25mm spacers due to only 255 wide winter tires. Now flush as wanted.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Drooling over the matte
Do the Topline fender flares get amounted over top of the existing, or do they replace the existing?
If mounted over top of the existing, are they secured by 3M tape?
Nice setup you have there.
Do you think, these Konis would work with the CS springs as well?
Do you notice a difference in braking, with that big brake kit?
Very very cool! (zombies)Now I be jelous!! Thumbs up!
H&R lowering springs + Koni carriage must be a nice feeling on/of the street. Big sport brakes to get it stopped is a good round up. I only know D2 brakes wich brake better then this corksport sportbrakes.
@Tibimakai - Allready with professional brake supply (pads&iDisk) on the Mazda brakes you will have a drastically different brake performance.
http://www.ebcbremsen-profi.de/ebc-bremsbelge/?gclid=CKLMhv6mt9ACFQIL0wodHkENfw
Take care that not every brake pad works or is suggested with every brake disc.
Regards 101
[/URL][/IMG]
These are not Topline, but same prinzip and you can see the 3M Tape on it. They are not white like Topline(no extra coloring needed they come in almost the same structure like the plastic on the car-or if you want to color them you would not need to color the whole plastic part at the car as well so that it looks not weird) Nice price + no extra toll/shipping from Japan(paid less then half of what I would have to spend for the ones from Japan). I wait till spring to install them. Now it's too cold.
Regards 101
Just put some new Bridgestone All Season tires on a few weeks ago and they handled our first snow of the year perfectly!
I did allready in other threads.
https://www.mazdas247.com/forum/showthread.php?123813324-Window-Tints-(-)/page8
https://www.mazdas247.com/forum/showthread.php?123817319-Show-me-your-wheels/page92
https://www.mazdas247.com/forum/showthread.php?123825779-The-CX-5-LED-Lighting-Thread/page53
And another perspektive of my avatar pic
[/URL][/IMG]
This 2Can Bus Modul is installed over the back viewing mirror- it comes with a LED wich I installed next to the support system buttons-it's glowing when the diesel regeneration of the skyaktiv engine is running. On this level you can see the oil water temp and the distance since the last regeneration. Batterie details and awd traction infos are on another level.
[/URL][/IMG]
Cheers 101
