"When there's pressure, the circuit closes to ground and the light goes off. Hence when you unplug it, the circuit is open = light stays on."
According to the Protege wiring diagram it's the opposite of what you say. It's on page 46of the wiring diagram. The diagram shows the switch must be closed for the light to be on. It's on the ground side of the bulb. On page 47 of the wiring diagram there is a note "Oil pressure switch, Closes when the oil pressure is low."
The Protege shop manual shows the shows the instrument cluster wiring diagram on page 09-22-2 and the circuit is the same as in the wiring diagram manual.
On page 09-22-13 of the shop manual is the oil pressure switch inspection (Quote)
"1. Verify the oil pressure warning light iluminates when the ignition switch is turned to the ON position.
2. Verify the oil pressure warning light goes off when the engine is started.
If the oil pressure warning light does not iluminate or remains iluminated, inspect the
oil pressure warning light bulb and related wiring harness.
If the oil pressure warning light bulb and related wiring harness are normal, inspect
the oil pressure. (See 01-11-2 OIL PRESSURE INSPECTION.)
If the oil pressure is normal, replace the oil pressure switch."
"Without looking at the wiring diagrams, it would be pretty dumb for the oil light not to come on if the sender is disconnected. Just think of it as a safety feature that alerts you that something is amiss. Like if your ABS isn't working, the light comes on to tell you that something's up."
Your comment make sense but most all the lights will run through a self check when the ignition switch is turned on. I'm just going by the wiring diagrams and what they show.
Clifton
