mspeedP5
Contributor
- '02 Protege5
Microtech LT10S
Used (obviously). Includes harness, manual, Software CD, dongle, USB adapter.
Reduced to $600 shipped in Canada. Elsewhere +shipping. Need this gone.
FUEL DELIVERY
4x Injector Drivers capable of 4amp Peak/Hold
True Sequential Operation on Most 4 Cyl & Rotary Applications
Can Run Up To 4x high Impedance Injectors Per Driver
Tuneable in MAP or TPS Modes
Main Matrix Table has 16x16 Load Sites
RPM Tuning Range 500rpm to 9000rpm
(10000rpm & 12000rpm Software Upgrade Available as an Option)
Overall Mixture Trim +/- 99%
Coolant Temp Correction
Air Temp Correction
Accelerator Pump Amount, Sensitivity & Time Compensation
Cranking Enrichment Correction
After Start Enrichment Correction
Cold Start Accelerator Pump Correction
Hard Cut RPM Limiter
Soft Cut RPM Limiter
Over Boost Limiter
Auxiliary Input Correction +/- 99%
Sequential, Group Fire & Staged injection Modes
2 Step/Launch Control Limiter
IGNITION
4x Ignition Drivers
Ignition Setup Preconfigured for Engine Type
Configurable to suit 1- 8cyl engines using an external igniter
Configurable for Twin Distributors & 2 Rotor Engines
16 RPM Based ignition Points
16 Map Based Correction Points
16 Water Temp Based Correction Points
16 Air Temp Based Correction Points
Ignition Advance/Retard on Accelerator Pump
Ignition Advance/Retard on Aux Input Trigger
Ignition Trim Overall +/- 45deg
Ignition TDC Reference Adjustment on Some Applications
Ignition Timing Split Adjustment on Rotary Engines
Accuracy to 1 degree
AUXILIARY INPUTS & OUTPUTS
1x Fixed RPM/MAP Based - ve switched AUX output (Shift Light etc)
1x Fixed Temperature Based - ve Switched AUX output (Thermo Fan etc)
1x Fixed - ve Switched PWM output (Idle motor)
1x +POS switched Auxiliary Input (2 step Limiter/Launch Control Etc)
FUEL DELIVERY
Air Temp Correction
Over Boost Limiter
IGNITION
4x Ignition Drivers
