I bought the system used with an X4. It took some time but I figured out that the X4 takes the -ve signal from the LT10S and turns it into a +ve. So basically I was trying to run the stock coils off the X4 when I shouldn't have. Made a jumper for the 4pin signal harness to the 6pin X4 harness so I didn't have to re-wire a bunch of stuff and she fired right up.
Just so everyone knows, I made a plug and play harness for my setup. Like the AEM adapter they sell for ~$250. Everything is wired in the pass footwell except TPS, and the extra water and air temp sensors that I put in. It's a freaking mess right now but I hope to have it cleaned up next week so I can run the car cleaned up as best as it can be.
Also, It started up with 440's on the "ImprovedStockInjector" map that Steve posted up. It's pig rich and I had to drop the crank values at 24 and 18 down to almost 0, but she starts every time. I thought it would take alot more to get her going. After I figured out the issue it started within 15mins of tinkering with the crank values.
Anyone know where I can do some good reading about timing? I know little about it and have googled about a zillion different things but cant seem to find any good resources giving easy to understand theory.
