fam said:Id worry more about the pot holes in NY than the snow.
canadianexpress said:The 16" rims are the same on the Mazda3 and mazda5. I got my package from GYRO Mazda, try them if you are living in Toronto. They do charge more for the Mazda steels if you don't buy the tires from them. They sold the Pirelli Winter Carving for $795 + tax (Tires & Rims).
was98strat said:What size did you use? I really like Pirelli Winter Carving but they don't make a size sutable for the 5. On 16 inch steelies we should be running 195/60 R16's
What size did you end up using?
wongpres said:Mazda5 on 16-inch, use P205/55R16 size
Zoom5Zoom said:minus 1 inch will not fit for stock 16 inch tires....17 inch you can drop to 16
Yes, P195/60R16 will work (i.e. it won't throw off ABS sensors or anything like that), but the factory Mazda5 tire sizes are:was98strat said:Minus 1 for tire sizing doesn't mean minus 1 inch on diameter (though I can see where the confusion miught come from. Plus 1 is an increase in rim diameter). tirerack and 2020tire both have good articles on Winter tires It means you take you stock tire tread width and go down 1 size . The idea is to get more PSI on the contact patch to get down through the snow better. So you go from 205 down to 195. Stay with the 16 inch steelies, but you go from 205/55 to 195/60, keeps the overall tire diameter the same with the increased contact patch pressure.
ansatzjp said:Probably a dumb question, so bear with me. If I buy snow tires (or winter tires), I should get them with rims (or wheels?), so I can keep the original tires at home to use it later? Oh, I feel embarrassed.
