Woohoo, finally got something done! Replaced air filter with K&N drop-in, changed the oil with Pennzoil 10W40, replaced spark plug with stock platinums, replaced stock spark plug wires with Magnecor 8.5 mm wires. I was going to drain/replace the coolant, transmission fluid and rear differential oil, but didn't get around to it...
On a weird note, I noticed one of the leading spark plug wires was unplugged. I don't believe I knocked it loose while working on the car, but it was definitely attached in some older pics. Is it possible for these things to get blown off and will the car run without one leading spark plug? Also noticed the noise is definitely coming from the steering - it creaks when the direction is changed drastically. There are a number of possible prognoses, but it's definitely not the steering fluid.
