I just drove 800+ miles yesterday and this morning my oil pressure light came on. Looks like I am down at least a quart of oil, maybe 2. I have had problems losing oil for nearly two years, but I just did a bunch of maintenance that I thought would fix the problem. I was losing oil in this same way before this stuff, so I doubt the leak was caused by it.
Here's what I did before taking this drive:
Replaced valve stem seals - I had blue smoke on start-up before, and now I don't
Replace cam seals, crank seal, and valve cover gasket
Replaced timing belt, water pump, and radiator
Oil change
I do not see any oil visibly leaking under the car. I also do not seem to loose oil unless the car is running. It lost next to no oil over the previous two weeks, when I wasn't driving much.
So... where else could I be loosing oil? What else can I check? I am traveling currently and only have a few tools, so I might have to wait till I am home to do a lot of diagnostics. The car runs fine too, it just loses oil.
Oil change
