lil_red_wagon
- lil white p5
Yes I know that and I will once I buy a cable to connect to laptop. Today I got a cel for PO134 which is for o2 sensor bank1 sensor 1 no activity. I think it was possible that when putting the ecu back into the place one of the wires might have came out from its connector. I got to check on that this week.
did you resist the o2 sensor to keep back a CEL? if so, the resistor may be bad now. also, all of the afr readings seem to be right. 11 is nominal for afr, but don't expect to constantly stay there. 15 is fine at idle.
