shane02pro5
25ish_psi
- New Caney TX
Well the instructions sound simple enough but for the TPS signal the J&S is saying to tap into my 02 signal wire, which with my Haltech F10 both 02 signal wires are run to +12 for constant open loop at over 30% throttle and under that my PLX wideband 0-1v signal runs into the Haltech for closed loop. My haltech also taps into the "TPS Signal wire pin 89" I would assume this is where to also tap in for my J&S or do I need to tap into my wideband 02 signal???
Anyone help please!!
Thanks
Shane
Thanks
Shane
