Hey guys, I just installed my cams and Cam gears in this weekend and was going to do a how-to but twilight beat me to it. I have no mechanical skills and this was the first time I've ever done it and it was easy as hell!! I could do this all day blindfolded now!!
Basically the only thing you have to watch out for is your timing! If everything is not at TDC you're screwed!! (at least I am at the moment!)
You could get RVT sealant at any Kragen, Pep Boys, Autozone...etc. and it would help to pick up some assembly lube.
Another caution, the bolts holding the cam gears in are tight! If you're by yourself (like I was) then just use a cresent wrench to hold the cam, and a socket to hold the bolt on the cam gear. Put a pole between them (like the one on your car jack) and use them as leverage against eachother.
Also, when installing the gears, put the exaust gear on first and tighten it down. Then grab the timing belt and pull it up until there is no more slack. Bring the slack over to the intake side and make sure everything is aligned!! To get the intake cam gear in, simply put the bolt through the cam gear hole, and into the cam. As you tighten the bolt, it will force the cam gear into place. Don't worry about stripping the bolt because it won't happen!!
Make sure to oil everything up and that's it.
