ok, i don't think this is on here, but the headlights are,so...here we go.
first, get under the front of your car, then look up towards the back of the fog light. you will see a single nut holding the fog light onto a bracket. take that and two washers off.
ok, now get out from under there(you grease monkey)...and pull the fog light out as far as you can, it dont come out far, be careful.
alright, you'll need either an offset screwdriver, or a ratchet and phillips bit. remove the two screws that hold the assembly together. pop out the glass part, and move the spring out of the way. unplug the wire ging from the bulb to the harness, and replace the bulb. ok, now put it back together, and got to the other side...CONGRATULATIONS, you've just changed your very own fog light bulbs.
