- 92 & 16 Meyatas
i shouldn't change them out unless i'm having issues though...?
yeah, don't mess with it. Linux and I have probably removed and replaced the exhaust manifold a couple times at least.bazooka joe said:i shouldn't change them out unless i'm having issues though...?
glyph said:yeah, don't mess with it. Linux and I have probably removed and replaced the exhaust manifold a couple times at least.
5 psi. I am losing out on a bit of power because i am maxing out my injectors. I can't seem to get any more fuel in there past 4500 rpm to even out my air/fuel ratios. I start getting pretty lean.THEGOLDPRO said:what psi were you running when you pulled 130 whp???
snowboards_20 said:can you run the car stock after you put a turbo in or do you need something to change the air and fuel
glyph said:5 psi. I am losing out on a bit of power because i am maxing out my injectors. I can't seem to get any more fuel in there past 4500 rpm to even out my air/fuel ratios. I start getting pretty lean.
you mean actually run the data log function with the haltech? Not recently. But when tuning after the initial install, when I got it to 130hp, around 4500rpm it was obvious that the fuel increases were making ZERO difference on the AFR curve on the dyno. That is a good question, however, and the next drive I make, I will do so. Unfortunately, I just haven't had time to sit down and give the car some tender loving care that it needs to finish this.LinuxRacr said:Have you logged your injector duty cycle?
snowboards_20 said:I just got my car back after getting the turbo kit install on my protege. I'm running 234 whp and 234 Ft/lbs with 10 psi. The car runs great.
well good luck with your return to the real world, lol when i got out i took 81 days of terminal leave, lol that was mint, then i collected unemployment for 6 months when my terminal ended, it was nice. lol so good luck manglyph said:It's been a busy year, new son, now gettiing out of the air force, TDYs, etc, so I haven't been able to get anything done with it. Since Jan. It runs really well, but I still need to fix the exhaust leak issue, again. I was missing a tool and had to button it up without completing the work. But, I have some terminal leave coming up, and the garage cleared out, so the work will be completed soon, properly this time.
Also, I am looking for a person with haltech tuning experience in the area that I can have examine my set up. I'm sure I have something wrong in there, as it's my only tuning job ever.
