Concept MSP
- 2003 Mazdaspeed Protege
Ever since I installed the Thunder Manifold I was hearing wierd noises from the engine. I sounded like a leak, kind of a high pitched whine. I thought it was maybe from the midpipe, by the flex joint. I decided to take everything apart to see what was going on and I saw this.
Both sides have evidence of a leak. The gasket and flange on the manifold are also covered with soot too. I took it to a local shop and we put a straight edge on it and it wobbled back & forth. Then I had them put it on the belt sander and you could very clearly see that the flange was not flat. After just a few seconds on the sander you could see that the belt was hitting just the middle, and not even touching the outside edges. I had them flatten out the flange, and I also drilled out the holes to 7/16. Hopefully everything will fit and work better the second time around. Just wanted to pass this along to any others that have this manifild in case you hear some leaks too. This was purchased as part of the first group by.
