Ok great sorry! Just trying to rule things out...
Not a problem, I appreciate the help!
If it's REALLY cold (sounds like it is)
I went on a 90 mile road trip yesterday and checked the level again this morning and it's down 3/4 inch from where it was at, and almost perfectly at the top fill hole now. So obviously any direct injection engine does not like short trips around the city in cold temps. This might be something for all of us in cold climates with short commutes to keep in mind.
Yes it's cold. -26c with windchill of -44c!!! I can try blocking the rad a bit bit I think it's pretty hard to access that area.. Plus, with the days of the manual fan being long gone, I'm not sure that is necessary for all in town driving. other than that, I'm starting to think maybe I bought the wrong vehicle for the kinds of driving I'm doing.... (hand)
well it's been a week and a half since I drained the engine to an acceptable level and the oil has risen again back almost up to where it was. I called Mazda and voiced my concern and they don't seem to think its an issue. His exact words are " The skyactive engine is highly technical and it will look after itself" So am I supposed to just take them at their word and remain driving a vehicle with an engine that is overfilled with oil? Can anyone else that lives in the bitterly cold prairie provinces in Canada verify if this is happening to them to ease my mind? I don't know what to do at this point and it's starting to affect my love for this awesome vehicle! (shrug)
Hi, I just read your message. I have the same issue with my 2013 cx5 gas engine. I have called every Mazda dealer I can and no answers. No one knows what to do with the problem of oil being diluted in cold weather. I check the oil daily during the winter and try to take it on long trips to bring the oil level down. I was wondering if you had yours fixed and if so what was the problem. thanks
I doubt it a problem as long as you stick to the severe service oil change interval but there are things you can do to minimize the issue. I realize how cold it gets in Manitoba and short trips with a cold engine is brutal on mechanical/electrical stuff.
Do not use premium fuel, only 87. Lower octane will combust more completely in a cold engine.
When refilling the motor oil, only fill it 1/3 - 1/2 above the low mark. This creates less pressure differential between the crankcase and upper engine which will minimize oil dillution. There is a slight benefit in that the oil will warm up slightly faster. It also prevents the crankcase from becoming overly full. Change oil on the severe service schedule.
As long as visibility through the windshield is good, do not idle the car to warm it up. Drive it moderately. An engine with a moderate load on it achieves a better seal between the rings and cylinders and the valves and valve seats which will reduce oil dilution. If you park outside, use a windshield frost blanket so it's not necessary to idle until you have defrost heat. At very low temperatures it takes a lot of idling to fully warm up an Skyactiv engine because the initial heat is mostly directed out the exhaust to bring the catalyst up to temperature. Once that occurs it will idle very efficiently even though the engine is not up to full operating temperature so driving it really is the best way to warm it up.
Do not drive at low rpm/high load until fully warmed up. It is better to keep the rpm's around 2000-2500 than under 2000 if you need to depress the throttle 50% or more. Do not drive at high rpm's (above approx.. 3500 rpm) until the engine is warmed up.
When you do take it on a drive long enough for it to be fully warmed up, drive it moderately hard using at least 3/4 throttle and higher rpm's (3500-5000). This helps the valve seats stay clean of fluffy carbon and wears the rings for a better seal. I actually think the bulk of your problem is likely due to not driving the car hard every couple of weeks (coupled with the short trips in arctic temps and a lot of cold idling).
Completely cover the front grill with a windproof fabric when driving in arctic temperatures.
I think your oil level will not rise if you do these things. In normal use it's not necessary but 5 minute trips under arctic temperature is not normal use!
You should do an oil analysis on the next 5,000 mile oil change and check for fuel dilution. I, too, have had some oil level increase with being gentle on the throttle and hyper miling my way to work. There's some good info at www.gf-6.com about issues with GDI engines, fuel dilution, "GDI Soot" and timing chain wear problems.
