NCoppersmith
- Mazdaspeed Protege 3.5
I have the iON 3" exhaust setup, and I need to pull the downpipe off to weld in a new sensor bung for my wideband (the old one is not optimally placed, to say the least) Looking at the setup (and forgive my ignorance) the piece I need to pull bolts straight up to the turbo and then to the cat. The two bolts connecting it to the cat should be easy. The four bolts (or more) holding it to the turbo, not so much. Two bolts I can get to easily from underneath the car, but it looks like for the two closest to the engine I'm going to have to pull the header off. (or exhaust manifold, whatever you call the part that says Callaway on it)
Is there an easier way? I'm assuming that if I can even get the header off (those bolts look dang rusty) I'll need to at minimum replace the gasket. Am I overanalyzing it or is it really that involved? (also have the iON FMIC and iNJEN SRI so the front of the engine is pretty roomy)
