The tool they use u can get at an auto parts store for $20, which is about what they would charge you to fix it. And if it happens again you'll already have it. If your into doing it yourself that is.paintless dent removal are not very expensive, and the results are amazing
how does paintless dent removal work? cuz i have a dent from some idiots door on my fender
What does it look like ? A suction cup on one end and then some type of screw or handle ?
I may go and pick one of those up - some asshat drop kicked my quarter panel.
I've managed to get the dent down from a size 11 boot down to the size of my fist with a 3$ sanding block and a WHOLE lot of hammering from the inside.
I used the dent king on my car and it worked very well and only cost me 20 bucks . if you want I live in boynton beach . if you pick it up i can help you out on day . im down to chill
