whitey4311
- MS3 GT Black Mica w/nav
Anyone know where to search or can hook me up if there is a way to unlock NAV so I can use it while driving?
I have looked into this and have not been able to find a way. The lockout is based on speed, not a contact like the neutral switch or hand brake. If you notice, it works fine stopped, like at a red light, and doesn't lock out until about 5 mph. Navs know what speed you are going so only a software fix will do it.tsunami said:I would think it is probably just a contact you need to over ride you just need to find a shematic and figure out which wire to splice and just hook up your own switch or to ground depending on what it needs to see to let you operate it...
