joshritger
- 2007 Galaxy Grey Mazda 3 S Hatchback (a.k.a. DILLA)
Today I got a CEL in my 2007 Mazda 3 Hatchback. I do not have any engine mods. The CEL I got was P2187 which says that the fuel system is too lean at idle on the right bank (1st bank). I have just cleaned my MAF Sensor and tapped on the Purge Valve Solenoid to make sure that it isn't stuck as these were the two most common problems I found related to this CEL. My question is, will the CEL go away if I have fixed the problem, if so how long will it take? Also if it doesn't go away with the problem fixed, do I have to reset the ecu in order for the light to go out?
Thanks for the help,
Josh
Josh
