OK For those of you that don't know how I will give this secrete away it is a must for a turbo'd car.
OK so alot of people want to run from a dig (From Standing Still)
There are some that want to do a 30 roll or 40 roll (From 30 MPH or 40 MPH)
For those that want to do it from 30 or 40 here is a trick called BRAKE BOOSTING.
It goes like this:
Agian Left foot on brake in desired gear while gas all the way down to build boost still at 30mph then let go of brake. CYA to car your racing (upyours)
*****IN NO WAY DO I CONDONE STREET RACING IT IS VERY DANGEROUS AND SHOULD NOT BE PERFORMED THIS IS AN FYI ONLY*******
It goes like this:
- Get the to desired speed in this case 30 mph, More then likely you will be in second gear.
- When your at 30mph (already in second gear) move your left foot over to the brake pedal and lightly apply pressure. (First time you try it you may over do it so keep practicing)
- While lightly applying pressure with your right foot floor the gas (you should here your turbo spool up or see you psi go up) apply ENOUGH PRESSURE ON BRAKE TO MAINTAIN 30mph the best you can while flooring it to build boost.
- When 3 beeps go off with the person your racing let go of brake and if done correctly you should already be at full boost so you should get a nice jump.
