It seems inevitable that the valve seals will need to be replaced I burn a ton of oil like I mean a lot a quart every week or more when I start the vehicle I get the cloud of blue and white smoke. So what options do I have pull the head and replace the valve seals that way and how would you recommend pulling the head? or should I try the old nylon rope trick with the camshafts off while replacing the timeing belt and water pump?
