Yep, thats about the only way. Anything that is watery enough to penetrate the carpet will also soak into the box. You could also SEM paint the carpet to the color you want it to be.Dexter said:Just start ripping it up...crowbar style?
You can try wiping it down with acetone but I don't think your going to get far. My path would be a metal putty knive to scrape of anything easy, then a belt sanderARunto said:How about the glue underneath? Should I just sand it off?
What adhesive did you use?chuyler1 said:sanding never works. you will have to bondo the entire thing to get a smooth surface. Better off building another box and selling that one on ebay or something.
On a side note, i learned this weekend that vinyl doesn't stick twice. I misjudged the opening for my amps by about 1/16 of an inch. They fit before I vinyled but not after. I pulled the stuff off, made the hole larger, but couldn't get it to stick again. I'm going to end up redoing the entire piece next time I get a chance.
