antilleybomb
- Black Cherry Mica 06' MS6
My husband is a Volvo mechanic and put my MS6 on a lift today to see if he could find the source of this popping noise I have in the front. He says the axle on the passenger side, going into the differential is loose and thinks it's a bearing because none of the other axles are loose. The CV joints are all good. Has anyone had this problem and if so, do you know what the fix is?
