Any kits using a small T25/T28 turbo ?
SR20DET
I've run across the spoolin' and "flyin' miata" site and all of the specific details aren't listed on those sites.
Looks like the spoolin' kit uses a T3 turbo of some variety ?
I have a brand new T28 ball bearing turbo for a 2001 S15.
Turbo specs:
Compressor: T-28, 60 trim 60 mm BCI-1 compressor in T-04B housing
Turbine: Inco turbine wheel. Cast divider wall between turbine discharge and wastegate.
Center Section: Ball Bearing
Does anyone sell a kit or at least a manifold(t25 flanged) that would allow me to use this turbo on my P5 ?
This turbo is close to being the perfect size for the P5 IMO and lag would be almost non-existent.
My thoughts for a kit are as follows....
S15 Turbo - Internal Wastegate is already set at 7psi (perfect)
Front mount Intercooler and Piping, nice downpipe and exhaust, slighty larger injectors and a good engine management solution.
I'd like to see around 175-200whp with this combo.
What standalones have you guys had luck with Haltech , etc?
Thanks for any input ;)
the T28 is probably the most perfect turbo for your application. it should bolt to a T3 flange.
my recommendation to you would be to see what type of manifold you would like (tubular or cast) and go from there
many guys here can get you a list of manifolds. If you would like some more info on a good manifold PM me and ill send you some info
Like nick said, it MAY bolt up, but I have no idea. If it doesn't, there may be some kind of adaptor to go from a T3 manifold to a t28. Either that, OR I'm sure terry could have them make a T-28 mani.
The t28 off the s15 silvia will not bolt up to a t3 flange. Get an adapter or have the flange custom fitted to a prefabbed manifold.
I think the site is www.fittings.com or something along those lines. They have all types of fittings so you can plumb the oil lines going to the turbo. A good thing is you won't have to worry about running coolant lines since the t28 is oil cooled only.
good to see a fellow turbo protege owner in northern va
oil cooling isn't very efficient for cooling a turbo unless you have an oil cooler before the turbo to help cool down the oil...water cooled is usually much better (especially for road racing)
Yeah we can make you a manifold with a flange for any turbo. Provide me with the flange and I can make it.
I can make you a stage 1 style header for 450 and 500 ceramic coated;)
Thanks for the info guys.... and BTW this turbo needs a T25 flange and is water AND oil cooled. I just so happen to have a HKS adjustable actuator for it too ;)
Latest posts
