Ok first off...this is going on protege5 with a stock block.
Here is the specs of a turbo i am looking at...
GT2871R Turbo
Turbine Turbocharger
.070
Pics of turbo
http://trendgears.com/ebay/MiragePower/Turbo/TurboT25T28-Nes-001.jpg
http://trendgears.com/ebay/MiragePower/Turbo/TurboT25T28-Nes-002.jpg
http://trendgears.com/ebay/MiragePower/Turbo/TurboT25T28-Nes-003.jpg
From what i can see...I should not have any problem bolting this up to a stock msp turbo manifold. The main thing im concerned about is the 8psi wastegate. Is there another wastegate i could use at a lower psi say 6? Or it that still at bit high for an aftermarket turbo with a stock block? If so, please point me in the right direction.
GT2871R Turbo
Oil & Water cooled
8 blade propeler for Compressor
Standard T2 (T25 standard based turbo housing)
Come with 8PSI Internal Wastegate (Can also be modify to use External Wastegate)
Compressor Specs :
Minor 54.12mm - 2.130"
Major 69.95mm - 2.754"
Compressor .49 A.R.
Compressor 60 Trim
T4 based compressor
Turbine Specs :
11 Blade Type for Exhaust
Turbine .64 A.R.
Turbine 77 Trim
Minor 46.25mm - 1.820"
Major 52.60mm - 2
Compressor Specs :
Compressor .49 A.R.
Compressor 60 Trim
T4 based compressor
Turbine Specs :
Turbine .64 A.R.
Turbine 77 Trim
Major 52.60mm - 2
Pics of turbo
