- @Squire0311; This is quoted directly from their now changed site, as
it was different since I had last visited.
Still doesn't mention anywhere on it that the kit is a DIY kit.
Some basic cutting I suppose could be taken as such; but it all depends how you would interpret that.
In no way is this a stab at you or anything Squire, just explaining the reasons of my claims, and my experience with them.
Note 1: "This kit has been specifically designed for the Mazdaspeed Protege.";
This is false, and there are many reasons why I choose to label it as such.
Many (Yes, not just one.) pipes are stamped with CXRacing somewhere on it.
CXRacing does not make a kit for any year Mazda Protege or Mazdaspeed Protege. 'Well, some kits may have the bends necessary to be so close to correct as to piece a kit together, so it may have well been made for the Mazdaspeed Protege.' - No. As I stated above,
I had to cut 7 of the 8 pipes to get them to fit. There are many arguments that could be made against this, but also as stated previously,
I do this for a living, professionally, in much tighter spaces, and much bigger consequences if any piece of it fails. In any case,
this kit was not specifically designed for the 2003.5 Mazdaspeed Proteges.
Note 2: "Some basic cutting is required."; If
basic cutting consists of cutting in a straight line, then yes, this is true. I
suppose this could be interpreted in a few different ways.
Basic in terms of, shave a little off the end, then no.
If basic in the sense of cutting in a straight line, sure; I can see that.
Po-tay-toe, Po-tah-toe.
These are my experiences,
it is up to you to judge my experiences, and to take the chance on the kit or not. Being a fellow MSP Enthusiast to all of you; If you were to come to me and say, "Hey, I've got 500 binkers and I want a FMIC, what do you think?",
I would send you to somewhere like CXRacing. Aluminum 2mm wall is Aluminum 2mm wall.
You will be cutting regardless, why not help out some of the dying population of MSP owners so you have a few hundred bucks to put towards *another* part you want? Whether your choice is this kit, or one from CXRacing,
your still getting a CXRacing kit.
